Dropping the Front Only????
RedCoupe92
Banned
Apr 26, 2005
34
Hey guys, I need help with this. I am going to be dropping the front of my car really soon. There is just too much wheelwell gap for me with the skinnies. It really needs to come down at least 2 inches, I think that would be plenty. The concern is this. I already have Moroso Drag springs in the rear, it's not lower, but they compress really easily for launch, plus I run 275/60/15 BFG Drag Radials, and they fit really nice with no rubbing, but I don't want a really stiff spring in the front, that would just make the car ride worse than it already does. I was considering 4 cyclinder front springs, will this bring it down the 2 inches I want? I was also considering Moroso Drag Springs for the front, but I didn't know if they would lower it without having to cut the spring. If I cut the spring, will it ruin what it was designed for? I don't mind cutting the spring, I just don't want it to not transfer the weight correctly. Any help you guys could give will be greatly appreciated. Thanks in advance.
the four cyl springs will drop it quite a bit,that is what i did on mine......
slow93, did you cut them at all, or just put them in the way they came? I know the weight of the front of the car has something to do with how low it will actually go. My battery is in the trunk, a/c has been deleted, fiberglass hood and aluminum heads, so my car isn't as heavy as factory. Do you still think it will lower it a good amount? Post some more pics of yours if you have any.
the only things that i have taken off are the ac and smog.i dont know exactly how much it dropped but im runnin 165r15s and they fill the whole wheel well.
