DSS 331, Vic Jr., RPM II -- What Cam?
Yellow302
789
NJ
As you can tell i need to get a cam for this motor.
Curently have a stage 1 TQ 2400 stall, fully built AODE.
I would be willing to up the stall speed to 2600 max i would rather not change it.
These aer my 2 options before going to some sort of custom cam..
N-41
302-347 c.i.d. This cam is to be used with 1 7 R.R. Great with TFS or Edelbrock heads. Minimum 30lb injectors and 80mm mass air. Recommend 3.73 to 4.30 gears. Good drivability down to 2100 rpm, lumpy idle, rpm range 2600-6200, works best with 89-93 EEC, needs 2800-3000 converter.
N-412
302-347 c.i.d. This cam is to be used with 1.7 R.R. Great with TFS or Edelbrock heads. Minimum 24lb injectors and 75mm mass air. Recommend 3.55 to 4.10 gears. Great drivability down to 1900 rpm, nice idle, rpm range 2400-6200, works best with 89-93 EEC, needs 2500-2700 converter.
95snoozer
2,571
RCR
a comp 274xe would work well with your auto
the n41 with 1.6s is 222/230 512 512 and with 1.7 i believe is .544 .544 and of course the duration will be a bit higher because of the 1.7s it will open up quicker
