will afm cam n-61 be good with my setup or to big.Here is the info on the cam
302-331 c.i.d. Best performer for 302 c.i.d. at 6200/6500 shift point. Great with TFS or Edelbrock heads 24 or 30lb injectors and 80mm mas air. Recommend 4.10 or 4.30 gears. Good drivability down to 2200 rpm, lumpy idle, rpm range 2500-6500, needs 2800 to 3100 converter.specs 224/236 dur and 545int/565ex
Here is what im running
sealed powered forge pistons
Edelbrock performer heads with comp springs
Staged 3 ported cobra intake
#24lbs and pro-m 75mm
65mm throttle body
Rest of the mods in my sig.
I do plan on a supercharger or zex kit with 125 shot pretty soon.
thanks
Jesse
65mm throttle body
thanks
Jesse
