Dual piston calipers made no difference. Normal?
Here is your advantages:
With a single-piston caliper, the footprint of pad is limited in some ways to the diameter of the piston. The diameter can only grow so large in relation to the rotor and brake pads. If the pad is too long, it flexes. When the pad flexes, it creates an uneven friction coupling on the rotor’s face. The uneven friction can create unwanted noise. If the flexing is sever enough, the friction material can separate from the backing plate. An example of this is the early Chrysler Neon. Also, there is a direct relationship between the diameter of the rotor and the diameter of the single piston caliper.
With dual- or twin-piston brake pads, the pads can be larger with even pressure distribution. A larger brake pad has several benefits. First, a larger pad will absorb more initial heat (less thermal shock). Second, a larger brake pad will have better wear characteristics and a longer life due to even pressure distribution. Third, a larger pad is able to absorb more unwanted noise and vibration because it is able to cover more of the rotor.
Another advantage is in the area of drag and fuel savings. With dual- or twin pistons, it is possible to have more aggressive piston seals that can pull back the pads more effectively after the driver removes his foot from the brake pedal.
