  • 1994 - 1995 Specific Tech
dumb question. broken motor mount
  • Thread starter Thread starter autumn_again
  • Start date Start date Feb 17, 2008
autumn_again
356
Hamilton, NJ
Feb 17, 2008
  • Feb 17, 2008
my dad was saying that he thinks i have a broken motor mount, by the way the shifter was shaking and moves under any kinda acceleration.
i also haven't been able to chirp second at all really, which i could do in my probe.
could the motor mount have anything to do with this, or is it just improper technique for shifting? i thought i should be able to spin em through second if i tried.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 17, 2008
  • Feb 17, 2008
He could be correct. Take a peek and see if any of the rubber on the mounts appears really cracked or torn. Take a peek at the balancer while you're under the car.
The shifting could be any number of things. Worn friction surface on the clutch disc or pressure plate, not getting your foot off the clutch quick enough, the clutch is out of adjustment, or good traction all come to mind.
autumn_again
356
Hamilton, NJ
Feb 17, 2008
  • Feb 17, 2008
yeah this thursday im geting under the car and taking a look with him.
its a brand new clutch and pressure plate, i pop the clutch right off, and they are pirelli tires off a stock 2006 mustang.
the engines fairly beat, its got over 200,000 miles on it, and burns oil horribly.
i am looking into rebuilding it, or geting a new block for this summer but for now i want to have a little fun haha.
i'm looking at a thing online how to adjust the clutch, i looked before in my car, and i couldn't figure out how to do it. i only took like 2 minutes because i had to head to school.
i'll try that and then go driving tomorrow.
anyone have any tips or a better explination of how to adjust the clutch?
1987Rock
114
  • Feb 17, 2008
Well, I don't think you can really adjust the clutch unless you have an adjustable clutch quadrant on your firewall...
BlownFiveLiter
18
108
Chicagoland
Feb 17, 2008
  • Feb 17, 2008
It's self adjusting with the factory quadrant and pawl. You just need to release the pawl and lower the pedal to the floor. After that you release it and it'll ratchet up and into adjustment. I think it's your engine being tired that won't let you chirp them though, with the new knowledge of its high mileage and oil usage.
1991 Fox convertible shakes
  • Blueinfan
  • Jun 18, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2024
limp
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Y
2004 Mustang GT AUTO (4R70W) Grinding noise when going in R or Drive does it as I put it into park too
  • yellowandblack
  • Dec 12, 2024
1996 - 2004 SN95 Mustang -General/Talk- Dec 21, 2024
89ripper
