Trying to wire up a tachometer, calls for one wire to be connected to a + source thats only hot when the ignition is 'on' and not when its in 'accessories' (or anywhere else i guess). Whats a convenient wire to use?
Also, i'm assuming the dimmer power wire will be one that goes from the dimmer switch to the instrument backing, so it should be obvious if you're looking up at it from under the dash... right? If not, some guidance on finding that one too would be great.
Thanks
Thanks
