so i can fill it from the hole in the shifter and itll drain down into the car? alright, how much fluid do i use? im using b&m trick shift full synthetic fluid.
You fill it until it comes out of the fill / check plug on the side of the transmission. Make sure you don't fill past that by leaving the plug in when you fill
