Fox dumping fuel at idle afr 10:1
  • Thread starter Thread starter Mattjhop23
  • Start date Start date Aug 5, 2024
First Prev 2 of 2
AeroCoupe
6,114
4,212
183
Claremore, OK
Aug 14, 2024
#21
  • Aug 14, 2024
  • #21
If you are going to stay with the stock block then I 100% agree with 2000xp8. The motor in my Coupe makes 460ish fwhp NA and I started looking for a better block as soon as I got the results from the engine dyno run. I can make more hp with a solid roller and pushing the rpm's but I am not wiling to grenade all the time and money I have in the motor.
Reactions: General karthief
Mattjhop23
23
Michigan
Aug 14, 2024
#22
  • Aug 14, 2024
  • #22
TOOLOW91 said:
Start checking vaccum lines and make sure nothing is off. Causing the car to suck unmetered air will make it do odd things
So I smoke tested and it was too, that was the first thing. So I checked the MAF harness plug I have 12v power I contacted pro-m and he told me to probe c&d and volts should move around “ I’m assuming with the car on to measure air” volts move to adjust air volume. So I back probed it and I got nothing I rev’d it a couple times and nothing stays at 0. I’m hoping he told me the correct wires if so I believe my MAF element is done. I’ll do it again just to be 100% and update again. Appreciate you all.
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Aug 14, 2024
#23
  • Aug 14, 2024
  • #23
2000xp8 said:
I don't think i'd waste time building out the fuel system for this engine.
IMO, just dial it back. 540rwhp is on borrowed time anyway not to mention the difference between 540rwhp and 500rwhp on the street is negligible.
I think people underestimate how long and how much money replacing an engine that split the block costs.
Blowing it up in epic fashion could be a 20k mistake that takes years to correct (if ever).
Agreed... How long does the burnout stripe need to be? LoL
Mattjhop23
23
Michigan
Sep 2, 2024
#24
  • Sep 2, 2024
  • #24
Welp I haven’t touched the car all that much. Kinda just been blah with the car since it’s been down for the big yearly shows I was trying to attend. Welp I’ll check vacuum lines today and fpr like someone mentioned I did get MAF checked out was good and put new wires and distributor in. Rotor and pickup was corroded but nothing same ole same ole. A tuner told me my sct chip could have went bad he’s seen it happen a few times. I think ima pull the O2’s and check what you all suggested. Sorry for the month wait just haven’t been motivated to mess with the car. I’ve burned through 2 sets of plugs idling the car for 10-15 minutes total. Plugs aren’t getting any cheaper that goes for anything nowadays. Have a good holiday weekend appreciate you all
Mattjhop23
23
Michigan
Sep 2, 2024
#25
  • Sep 2, 2024
  • #25
So I pulled vacuum line from fpr it’s fed to the side of the upper intake, well I pulled it and fuel is dripping out of it. So. Fpr is leaking?
89ripper
926
308
103
Rockford, Illinois
Sep 2, 2024
#26
  • Sep 2, 2024
  • #26
Sounds like the diaphragm is, yes.
Mattjhop23
23
Michigan
Sep 2, 2024
#27
  • Sep 2, 2024
  • #27
Welp I pulled the upper completely filled with gas. Should I pull the lower intake and check it out? Really don’t “want” to seeing I just redid the lower intake beginning of summer
89ripper
926
308
103
Rockford, Illinois
Sep 2, 2024
#28
  • Sep 2, 2024
  • #28
What fpr are you running? I would start there. The diaphragms go bad and suck gas through vacuum line
Mattjhop23
23
Michigan
Sep 2, 2024
#29
  • Sep 2, 2024
  • #29
It’s a aeromotive that was on the car when I got it. I’m going to swap it out I pulled upper intake was filled with gas so I don’t want to but I guess I should pull the lower intake to?
General karthief
Mod Dude
Aug 25, 2016
28,029
10,654
213
polk county florida
Sep 2, 2024
#30
  • Sep 2, 2024
  • #30
Shouldn't have to pull the lower, no place to puddle.
Reactions: Mattjhop23 and 89ripper
AeroCoupe
6,114
4,212
183
Claremore, OK
Sep 2, 2024
#31
  • Sep 2, 2024
  • #31
You can get a rebuild kit for the Aeromotive FPR, just saying.
89ripper
926
308
103
Rockford, Illinois
Sep 2, 2024
#32
  • Sep 2, 2024
  • #32
Yes i have had to rebuild aeromotive fpr before its fairly simple to do
TOOLOW91
20+ Year Stangneter
8,752
234
S.I.NY
Sep 3, 2024
#33
  • Sep 3, 2024
  • #33
Rebuild fpr , put it back together and set fuel pressure . Run it it’ll burn all that excess out in a few mins
If you’re nervous about cylinders full of fuel pull plugs and crank motor a few turns. Also and a big one !!!! Do not run the engine another second without changing oil. I’m sure it’s beyond washed
Reactions: 89ripper, Cheapskate207 and AeroCoupe
Mattjhop23
23
Michigan
Sep 3, 2024
#34
  • Sep 3, 2024
  • #34
Yea I have some rotella in swapping oil today. This fpr has seen better days. It plums into fuel rails “stock rails” I know rails are maxed injectors are maxed fuel system upgrade this winter. But around by the o-ring is banged up missed a screw in the bottom other one is stripped. I’m just going to order a new one and have no worries about it. I’m sure cylinders will be washed down by the time the new one gets here and installed. Only thing is my v2 pulls oil from the pan and runs it through it so supercharger is been pulling gas soaked oil .
First Prev 2 of 2
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
W
  • Locked
Fox Wifes 1993 LX 5.0 dies after replacing ignition parts
  • Warhorse85
  • Aug 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2025
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
