Dyna-batt and daily driver?
Flash1966
829
Orlando, Florida
Does anyone use a dyna-batt in a daily driver stang? I'm going to be upgrading my alternator soon and I read the article in Jan 05 MM&FF where they do the alt and a dyna-batt and it looks pretty good, plus the weight savings is really nice. I'm just wondering if this battery will stand up to daily abuse, I drive about 50 miles a day and spend my fair share of time in traffic.
I'd love to just relocate my batt to the back, but I have a hatchback and don't really want to have a big box sitting in my car, plus it's more expensive than the dyna-batt too.
I wouldn't put anything other than an optima or dyna batt in the back. Even sealed 'maintance free' batteries discharge lots of hydrogen. Something I don't want in my car. Optima/dyna batts only discharge under extreme loads and is minimal.
Dry cell batteries take abuse a lot better than wet cell, discharge hardly nothing, and have no liquid acid to spill/explode. Battery location is important. With the stock battery, you are removing over 30lbs form the front end and putting it where it is needed. I have a group 34 size battery in the back of mine with the Taylor kit, it has the power of the optima but is larger and heavier, when it dies I am getting a optima. I say optima because I work for a company which deals with Interstate which sells the optima also, can get a lot cheaper.
The Dyno Bat has been around for a few years now.Im definitly getting one :nice: Its alot lighter,and has power.I saw that article too,Im getting the alt. also :nice: If you have UD pullies its a must!!
motorcycles dont like to start at 10* either! bike batteries have no CCA cuz one has to be nuts to ride when it is That cold out! LOL.
how about: one could have one of those portable jump starters around (the kind that charge on 110 and you put in your trunk) for "just in case". it would give a boost on colder mornings too (if someone is really gung ho to do this).
All batteries perform much less when it is cold. That is why the CCA (cold cranking amps measured at the freezing point) and the CA (cranking amps, I think measured at 70*) is always higher. My battery 675CCA 850 CA.
