Dyno Numbers are In...
ok with my mods in my sig, I made 245rwhp & 279tq, I'm not sure if the loose converter is affecting my numbers.
The tuner thinking the stall is more like 3800-4000rpm instead of the 3600rpm that I requested. The feel strong but I'm not sure if the converter is giving us that feeling.
Kurt
Kurt2002 said:
those numbers don't seem out of place? I was hoping for 260rwhp lol
I think they are...compared to me anyways.
You've got these parts over me:
Long Tubes / No Cats / Plenum / TB / TC
Yet you only dynoed 10 hp over me??? Doesn't look right...
(Ignore the TQ...I think they were inflated by the dyno...Dynoed 270ft/lbs before)
Kurt
Whats your best 1/4 times with all the mods? Gotta be good with the tq cnvtr.
sorry guys, was away for awhile, yes the tuner locked the TC for the pulls.
Also I found out the builder used the wrong pistons and dropped my CR to 9.0 to 1. That did not help the numbers at all.
I have yet to get new times with this setup since it is winter in Ohio.
I guess I'll let the times at the track tell me if it is stronger or not lol
Kurt
If you're compression ratio is dropped, then that is probably why you're below the 250rwhp mark. That, and since your torque converter is multi-disk, you have to remember that the more disks you run, the heavier that torque converter becomes, and the heavier the converter, the more numbers you loose at the wheel. As you said, the loose converter might be causing a some what low read out.
