  • 1994 - 1995 Specific Tech
Dyno Numbers Finally
  • Thread starter Thread starter krahkin
  • Start date Start date Nov 2, 2004
krahkin
183
Acworth GA
Nov 2, 2004
  • Nov 2, 2004
After waiting for who knows how long, I finally got down to Team Ford Marietta and got my dyno tune. Not only did they fix my idle, but they helped me locate some other trouble spots I had. Back to the numbers. Jeff at Team Ford told me to chunk my intake and replace it for a good 25 rwhp, which would put my numbers up to where I expected them to be.
265 rwhp
299 rwtq
SorsCode
20+ Year Stangneter
Jun 10, 2003
1,022
432
113
St. Louis, MO
Nov 2, 2004
  • Nov 2, 2004
you have an auto or 5spd?
T
Touring23
294
Washington
Nov 2, 2004
  • Nov 2, 2004
I see the mods in your sig, are you using the stock exhaust and intake/MAF/TB? I'm glad to see such numbers from a cobra IM.
zenboy99
2,212
Madison, WI
Nov 2, 2004
  • Nov 2, 2004
We need more info about your combo, those numbers could be right on or too low.
krahkin
183
Acworth GA
Nov 2, 2004
  • Nov 2, 2004
1.6 roller rockers, 70mm t/b, 76mm mas, bbk longtubes with catted h-pipe, 30lb injectors
stock 5-speed, eaton posi, 31 spline moser axles, 3.73s
the recommended intake was an edlebrock performer (by the tuners) I may see if tmoss still wants to port my cobra first though, im curious to see what it would do.
edit - they also recommended a larger NA cam since my blower isnt on yet
zenboy99
2,212
Madison, WI
Nov 2, 2004
  • Nov 2, 2004
What was your timing at? How about your air fuel ratio? I would think you could get another 20rwhp with that Cobra intake, it isn't that much better then a Performer
T
TMC
1,426
Chicago
Nov 2, 2004
  • Nov 2, 2004
I agree that there is more power in an intake swap I don't think that your intake is at the limit of the power that it can make. Cobra intakes can make 280 RWHP without really sweating. 300 RWHP is possible but at that range it's getting a bit harder. 320+ is possible but the intake would be a big restriction at that point.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Nov 2, 2004
  • Nov 2, 2004
Your giving up significant power if your lower is a stock Cobra lower. I can fix that for you - PM me if you want details.
9
96darkhorse
693
wilmington, california
Nov 2, 2004
  • Nov 2, 2004
i think your numbers are pretty low
belzebub2u
164
Woodstock GA
Nov 2, 2004
#10
  • Nov 2, 2004
  • #10
where you live at Krahkin?
krahkin
183
Acworth GA
Nov 3, 2004
#11
  • Nov 3, 2004
  • #11
tmoss - lower intake is a stock cobra lower and does not match my 1250 gasket
belzebub - GA
tmc - i agree that a cobra intake could make lots of power, i just need to get the lower port matched to my heads?
T
TMC
1,426
Chicago
Nov 3, 2004
#12
  • Nov 3, 2004
  • #12
I think that would be a good economical start but don't simply port match the lower. Have the entire lower ported and port matched.
95snoozer
2,572
RCR
Nov 3, 2004
#13
  • Nov 3, 2004
  • #13
ok ok ok this HAS to be a mustang dyno and not a dynojet
Houston94vert
375
Houston
Nov 3, 2004
#14
  • Nov 3, 2004
  • #14
Here's my numbers.
262 rwhp
293 ftlbs rw.
Mods
f-303 cam, header shorties, o/r x-pipe, borla catback, 3:73 gears, aluminum drive shaft, under drive pullies, and k&n filter.
Stock cobra bottom end, heads(steel gt40s), intake, and throttle body.
With those heads you should be in the 300hp at the rear wheel range.
krahkin
183
Acworth GA
Nov 17, 2004
#15
  • Nov 17, 2004
  • #15
Just to clarify a couple things. The cobra intake is untouched upper/lower. The AFRs are the 61cc stud heads (not the 58cc - planning on blower next year). Do my numbers still seem low, or do they seem about right? My bottom end has roughly 80k miles on it and could possibly play a factor?
Black Stampede
1,811
Grand Rapids, MI
Nov 17, 2004
#16
  • Nov 17, 2004
  • #16
Like Snoozer said, are you sure this wasnt on a mustang dyno?
HoofnIt
1,175
North Carolina
Nov 17, 2004
#17
  • Nov 17, 2004
  • #17
Check out my sig for details and dyno #'s. I had tmoss port the cobra lower. IMHO you should be putting out more power.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Nov 17, 2004
#18
  • Nov 17, 2004
  • #18
Said it before.............never mind.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Nov 17, 2004
#19
  • Nov 17, 2004
  • #19
There could be lots of reasons why the numbers did not climb as high as you expected.
You did not give details about the tune such as af ratio, spark and the like.
Most na h/c/i combos can gain at least 10 rwhp by someone who knows how to manipulate the spark/fuel tables.
I've seen combos that had after market maf's be pig rich or dangerously lean.
Did the motor have time to cool between the pulls?
More than once I've seen intake ports covered 1/8 of an inch by the gaskets.
How many miles on the short block?
Later
Grady
N
Dyno Issue with 2015 GT
  • Nickos.Ford
  • Jul 11, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 11, 2025
Nickos.Ford
N
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 3, 2026
squeak93
LT headers/ CEL misfire
  • Starxk
  • Jul 28, 2025
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jul 28, 2025
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
