  • 1994 - 1995 Specific Tech
dyno numbers
  • Thread starter Thread starter hernandez
  • Start date Start date Jul 23, 2006
hernandez
44
  • Jul 23, 2006
to day i dynoed my 94 gt and made 258.64 rwhp and 286.95 rwtq, mods are 306, 70mm CAI, 65mm T-Body, F 303, Edelbroc RPM Heads and Intake, 19lb injectors, BBK Equal Length Headers, 4.10s, 1.7 Roller Rockers. Do the numbers look right or should there been more horsepower and torque
fiveoho
1,958
TN
Jul 23, 2006
  • Jul 23, 2006
sounds a little on the low side to me considering your mods....
WhiteDevil
2,717
San Diego
Jul 23, 2006
  • Jul 23, 2006
Yeah with my H/C/I set up i put down 298rwhp and 326rwtq. Were u super lean or something? Your injectors are too small for your combo.
mootang
907
texas
Jul 23, 2006
  • Jul 23, 2006
deffinatly sounds low for your mods!
hernandez
44
  • Jul 23, 2006
i thought so , what do you guys think i should do to get my hp up?
sage2k
645
Baton Rouge, LA
Jul 23, 2006
  • Jul 23, 2006
injectors/maf and tune
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Jul 23, 2006
  • Jul 23, 2006
Numbers might come up a bit with some time on the dyno playing with A/F and timing...but IMO if it drives well and the curve was good/car's fun to drive...I wouldn't touch the valve covers.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 23, 2006
  • Jul 23, 2006
It would be helpful to know if you got an auto or stick trans
Grady
9
94gtslow
401
Temple,Texas
Jul 23, 2006
  • Jul 23, 2006
sounds a little low, what was the air/fuel ratio?
And aslo what kind of transmision do you have, there are a lot or variables.
mootang
907
texas
Jul 23, 2006
#10
  • Jul 23, 2006
  • #10
he has a T-56 according to his sig!
hernandez
44
#11
  • Jul 23, 2006
  • #11
it has a t-5 with heavy duty gears, and the t56 is in my other mustang, my air/fuel was around 13.3-13.5
mootang
907
texas
Jul 23, 2006
#12
  • Jul 23, 2006
  • #12
what is your base timing? also what kind of dyno was it? mustang dyno maybe?
Killercanary
The car that set the bar.
Altoona, PA
Jul 23, 2006
#13
  • Jul 23, 2006
  • #13
Mid 13's is kind of on the lean side for NA engines. All engines are different, but typically from what I've seen an A/F ratio in the high 12's to low 13's will produce the most power on street H/C/I setups. Throw some fuel at it and see what happens.
Very good questions.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 23, 2006
#14
  • Jul 23, 2006
  • #14
I see I was correct in my assumption you were talking about different Stangs
I'm with Paul about a fatter ratio producing more ponies.
The other Q's about dyno type and how you had your spark setup certainly can effect final hp/tq values.
Those 19's are tooooooooooo small
With those 410's ...at WOT ... a heavy load in say 3rd/4th gear with rpm's rising quickly ... you'll have conditions very favorable to produce lean ratios ... even the more so if you still got the little oem pump.
You need more fuel .......... period
At the VERY LEAST ..... work those little 19 with more pressure
Grady
hernandez
44
#15
  • Jul 23, 2006
  • #15
just bought some 24lb injectors and a 70mm tbody w/tfs elbow, as for the maf it was a 75mm not 70mm. i hope this will put me up to par
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
Fuel 19lbs EV6 fuel injectors, what fuel pressure???
  • PonyGTrider
  • Jul 11, 2024
  • 6 7 8
13K
Fox 5.0 Mustang Tech Jul 25, 2024
PonyGTrider
