Twistedoffpurp
- Sep 20, 2006
- 13
- 0
- 2
VibrantRedGT said:If I owned a 408 I would do.
AFR 225's
Custom Cam with around .600 lift
90MM Fox style Throttle Body
Pro-M 80MM MAF
AFM 4 inch Fox style cold air kit
42lb Injectors
1 7/8 Kooks Long Tube Headers
3 Inch Prochamber
3 Inch cat back
Look at post #5 (Low 5.0) and read his sig. You should have his parts and his dyno numbers.
I'm gonna agree with most of this, if I was to build this I would get the EFI spider intake setup. The lightning MAF(on ebay it's like $80) www.massair.com obd1 to obd2 adapter harness, possibly convert the harness to a fox harness get either an A9L or a cobra computer X3Z. Try to get a JLT true cold air setup and modify it to fit, I can run my car wide open stop get out of the car and grab ahold of that thing and the outside of it is just above body temp.
