Dyno results...
tonys5.0
122
Jacksonville, FL
Today my car was dyno-tuned by Tony at HP Performance. First of all, Tony is an awesome tuner and I highly recommend him! Based on the mods in my signature the result was 267.28 Max Power and 310.70 Max Torque. With a 100 shot of nitrous it was 325.42 HP and 394.86 Max Torque on a conservative tune. I didn't have a bottle warmer and my nitrous bottle was pretty cold so the Max HP should be higher with correct bottle temp. I'm saving for heads and cams next but after next years tax returns I'm really considering the single turbo route.
Are these respectable numbers?
The other thing I would like to add is that on the road the car feels much faster with the the suspension work and weight loss.
You're making great power off the bottle.
Which nitrous kit are you using? I'm guessing not NX? Numbers look good, but a little low even with a cold bottle. (makes me anxious to get my bottle filled up)
It's the zex wet kit. I bought and installed it almost two years ago but never ran it until now. Because it's not my daily driver it's been sitting in the garge getting worked on all this time.
I'm pretty happy except I wish I had installed the bottle warmer and I'm not sure if I will keep the zex kit or go with a different set up. I'm seriously kicking around the ideal of installing a single turbo set up and I'm definitely switching out the flows for a set of dynomax mufflers and x pipe.
The thing I'm most happy with is going to an aftermarket k with tubular control arms and coil-overs. The difference in handling and SOP from weight reduction is great compared to stock!
