Dynoed the 347....w/o the supercharger
n2fastuff
As I am fortunate enough to have a Stuska Powertest ENGINE Dyno at my disposal at my father's shop, I ran the engine in on the dyno just to see where we stood, sans the injection and charger. This is a 347 with the following pieces thrown into the mix.
Stock block - Canton girdle and windage tray
Canton 7 qt pan
PBM rotating assembly (short 5.325 rod,16cc dish Mahle Piston,cast crank-28 oz)
Edelbrock perf 5.0 heads...lotta work on the exhaust,minor on intake side
Steeda 19 cam 220/226 @.050 115 LSA... small blower cam
PBM valvetrain...145lb seat/310 open, AMERICAN MADE stnlss valves
Weiand Stealth intake dual plane(INJ Man. is 94-95 cobra - ported)
750 holley Vaccum secondary dyno test carb
schoenfield dyno headers
PLEASE keep in mind that this engine is only 8.9:1 compression ratio with .022 top and .026 2nd ring gap for charger) and will be injected with a Vortech S-trim and on pump gas for the street. I.E. not a race engine
2600 RPM -400 lb/ft:) - 198 hp
3500 RPM -425l/ft - 283hp
4000RPM - 431lb/ft - 328 hp
4500 RPM 443 lb/ft(peak) - 371 hp
5000 RPM 427 lb/ft - 407 hp
5800 RPM 417 lb/ft - 426 hp(peak) :)
These digits are respectable for PRE-BLOWER #'s. Hope the 42 lb/hr MTRSPRT injectors are enough! This is expected to bring 450-470 at the tires and be FUN to drive...to the grocery store and car shows... chuckle
Thanks....William
