  • SN95 4.6L Mustang Tech
e brake cable
  • Thread starter Thread starter KILLER EX
  • Start date Start date Jun 12, 2006
KILLER EX
50
Gloucester,Mass
Jun 12, 2006
  • Jun 12, 2006
i broke my cable where it attaches to the handle i called my local dealer and tried to order one and they keep telling me i have 2 cables comming up through my floor my car only has one comming up through the floor.. what gives anyone run into this before? it is a 1997 gt
MT1083
1,033
Charlotte, NC
Jun 12, 2006
  • Jun 12, 2006
try getting in touch with Randy Stinchcomb.
hognutz
1,940
albany, oregon
Jun 12, 2006
  • Jun 12, 2006
if you only have one cable coming through the floor they are wrong. mine is an 01 but there is only one and there is a part number for it as I had to replace it. one tip once you find it is make sure know how to use the tentioner in the ebrake handle. you rotate if forward and hold it in place with a pin. I did not relize this at first and could not figure out why I could not get the ebrake cables pulled back into place. once you uncoil the tentioner so to speak you can do it ease.
talk to randy or call a different parts department that actually knows wtf they are talking about. sometimes I hate parts departments. they act like you are stupid and they are the ones that don't know thier a$s from a hole in the ground.
RandyStinchcomb
1,159
Randallstown, Md
Jun 12, 2006
  • Jun 12, 2006
thanks guys
common problem on older 'Stangs. you need part # F4ZZ-2A603-A fits 1994 to 1998 Mustangs and we sell it for @$26.00
KILLER EX
50
Gloucester,Mass
Jun 12, 2006
  • Jun 12, 2006
is that the ford part # ?
RandyStinchcomb
1,159
Randallstown, Md
Jun 12, 2006
  • Jun 12, 2006
yes it is
KILLER EX
50
Gloucester,Mass
Jun 12, 2006
  • Jun 12, 2006
thanks a ton!!! so i was not missing something there is only one cable comming through my floor?
tomustang
Psychotic Member
3,434
McLean Hospital
Jun 12, 2006
  • Jun 12, 2006
RandyStinchcomb said:
thanks guys
You need to open your own website
RandyStinchcomb
1,159
Randallstown, Md
Jun 12, 2006
  • Jun 12, 2006
I dont have the time, as Im too busy spaming away on everybody elses sites
RandyStinchcomb
1,159
Randallstown, Md
Jun 12, 2006
#10
  • Jun 12, 2006
  • #10
correct, both left and right rear cables come up and join wth the "2A603" which has a short cable that goes upto the hand brake
tomustang
Psychotic Member
3,434
McLean Hospital
Jun 12, 2006
#11
  • Jun 12, 2006
  • #11
I should've ordered from you insted of mod crapo, I would've got my parts
KILLER EX
50
Gloucester,Mass
Jun 12, 2006
#12
  • Jun 12, 2006
  • #12
thanks sooo much!!!
CRZYHRSGT
240
5.7 miles north of THE Ohio State University
Jun 12, 2006
#13
  • Jun 12, 2006
  • #13
hognutz said:
...a different parts department that actually knows wtf they are talking about. sometimes I hate parts departments. they act like you are stupid and they are the ones that don't know thier a$s from a hole in the ground.
That's why I can't stand my local Ford stealership. They have "over 100 years combined experience" at sucking. They should try looking up parts for Italian/German/ British cars sometime. I couldn't tell you how many times I've wanted to jump over the counter and do their job for them
GDawg
1,469
Nevada
Jun 12, 2006
#14
  • Jun 12, 2006
  • #14
Randy is definitely an asset on this site. He's helped me out before in both price and info...
RandyStinchcomb
1,159
Randallstown, Md
Jun 13, 2006
#15
  • Jun 13, 2006
  • #15
thanks guys I enjoy being around here too:SNSign: .....well, sometimes
SweetPeaSLE
#16
  • Dec 27, 2007
  • #16
New question for Randy from an old thread
Quick question for you Randy:
I have a 1996 3.8L mustang with the same problem. You said the part # fits 1994 to 1998 mustangs but I wanted to be sure it would fit mine since it's not a GT.
Also, when I had it checked at the dealership they said the ratchet assembly and cable would need to be replaced. What is considered to be the ratchet assembly? I have not taken it apart to get a better look, but looking at it the only thing that appears to be wrong is the broken cable where it's supposed to be attached at the handle and everything else appears to be intact. Any suggestions?
Thanks,
Sandra
RandyStinchcomb
1,159
Randallstown, Md
Dec 28, 2007
#17
  • Dec 28, 2007
  • #17
Thanks,
Sandra
ok, the ratchet asbly is another name for the parking brake asbly and 1994 to 1998's are all the same for the "2A603" base, Gt and Cobra...do you have access to a fax?
SweetPeaSLE
#18
  • Dec 28, 2007
  • #18
Parking brake assembly info
I do have a fax number at work, it is 540-387-5507 and my name is Sandra Elliott. Thanks for your help!
RandyStinchcomb
1,159
Randallstown, Md
Dec 28, 2007
#19
  • Dec 28, 2007
  • #19
ok, Im gonna' send you an exployed view of the parking brake asbly, hope it helps...if you have any further questions, you can reach me at 410-655-3188, thats a direct line into parts.....
SweetPeaSLE
#20
  • Dec 28, 2007
  • #20
That helped a lot. I have the parts ordered & will be able to fix it on Monday. Thanks so much for all your help!!
It looks like the repair won't be too difficult, do you have any suggestions on anything to watch out for that may give me trouble?
Sandra
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
identifying smog/fuel part on 1998 GT
  • dochawk
  • Jun 18, 2026
SN95 4.6L Mustang Tech Jun 30, 2026
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Parking brake cable
  • 78 Mach1
  • Apr 21, 2025
1974 - 1978 Mustang II Talk & Tech Apr 30, 2025
78 Mach1
Brakes How do I get the e brake cable onto the disc brake caliper??
  • AnthonyA1234
  • May 2, 2025
Fox 5.0 Mustang Tech May 2, 2025
AnthonyA1234
