E brake light flashes while accelerating????
kevsstang
143
pa
Well took the car for a ride and while under heavy acceleration the emergency brake light came on for a second or two and then went off. Did this in each gear, i pulled over and set the emergency brake a couple times. I started to drive again and under heavy acceleration it did it again. What would cause this?
kevsstang said:
Thanks Grover, I will check the fluid out tomorrow.
if it's not that see if the handle is loose and moves when you accelerate. my does it every once and a while....or if I have a pair of sungalsses or something in that cavity...I said cavity....sometimes it's enough to lift it to trigger the sensor
