E brake problem
  • Thread starter Thread starter my89notch
  • Start date Start date Feb 3, 2007
M
my89notch
  • Feb 3, 2007
Hey Guys,
Ive read several threads about how to fix your e brake, but nothing has helped me. I just bought my first 89 coupe and took it straight to the inspection place. everything passes, but not my e brake. I took the car and had a full brake job done and the guy said my e brake was fixed, but when i got home and tried it, the brake still didnt hold. I need some advise so i can get my car through inspection. any help at all..
Sincerely, my89notch
F
facemelter71
60
cincy
Feb 5, 2007
  • Feb 5, 2007
Tell ya what,i dont know where you took it to but they should repair it for free,but if not.Pop the drums off and at the bottom of the shoes there is a round adjuster wheel that adjust the shoes further out or in just turn it one way or the other to adjust the shoes OUT and keep checking the fitment with the drums to make sure you dont get them to tight.Check and see if that helped,it should,then on top of that there is a nut on a threaded rod at the base of the e-brake handle,you can adjust there to,just make it a last resort if you can.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Feb 5, 2007
  • Feb 5, 2007
or just take the small rubber plug out on the back side of the backing plate and adjust the adjuster with a flat screwdriver in the hole.... you want it to just start to drag.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Feb 6, 2007
  • Feb 6, 2007
The stock handbrake sucks, the cables have stretched over time and the best badaid you can do for now is to adjust the rear brakes and see if that helps.
Brakes are engaged while driving
  • stevetbright
  • May 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 31, 2026
stevetbright
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
A
Resolved Brake light switch
  • Alabama
  • Feb 24, 2025
4K
General karthief
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
