Guys,
I have a E303 cam in my AODE car. The car had no brake problems before I installed the new motor. Now, when just backing the car up while idling, the brake goes almost completely to the floor before I feel the brakes catching.
I tested it and the vac = 8-10lbs at a 900rpm idle.
When stopping from 50mph, the brakes are better but they are still allot worse then they used to be with the stock 302. I know a cam like the E303 lows vacum, but if it effects the brakes on a SN95 to this extent, I won't have gotten it.
What should the Vac be lbs_wise with the E303 ???
Is there anything I can do to get better brakes ???
Has anyone else with the E303 in a SN95 experienced this problem ??
Thanks...John
Thanks...John
