in mechanical terms, the lsa is the difference in degrees from intake centerline to exhaust centerline, this dimension also plays with another measurement called overlap, the wider the lobe separation you have, the less overlap there is, creating stable idle vacuum, and almost instant throttle response. the narrower the lobe separation, the more overlap you will have, creating more erratic vacuum signals which also creates that intoxicating lopey idle which we all love so much. the low end may suffer slightly, but the midrange will knock your socks off and pull like a freight train...provided that you match your components correctly, either one of those cams will help that car run like a scalded a$$ ape. personally, if i were going to run either of those cams, i'd probably go with the performer rpm intake as the lower performer will kinda restrict you a little bit. i know you said you're not too concerned with top end, but either of those cams will probably make usable power up to 5800rpm (beyond the range of the performer low rise intake.)
you see my combo in my sig, the comp 270 runs 110* lsa, 270* total duration, 224* @ 0.050", i run the rpm intake, and before it started suffering here within the last 10k miles, it used to pull from 1500 to past 6000.
there's lots of ways you can increase low end or at least low end "feel"...a good way is if you'll be running an auto to put in a stall...a 2400 will get the r's up into your torq and power band quicker, and make the car get out of the hole alot quicker...
