E303 cam surge
fox04
78
augusta, ga
My car is a 88 gt. It has alum. heads e303 cam, t5, 373s etc etc. when cruising around town between 1500-2100 the car jerks really bad like the cam is surgeing. The idle is perfect and doesnt surge at all so could it be a different problem rather than cam? Im not really sure what else to check.
I bought the car with the mods already done and has done it since day 1. The car is maf converted. Have not pulled any codes. the car runs great though thats the only problem ive noticed. It does run rich though.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 3-Jun-2011. Removed the link to BATAuto.com and troublecodes.net instructions on codes and how to dump them. Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 Mustangs at this time.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
I have the same problem with my TFS Stage 1. I have no codes and engine runs very well, no surging at idle. I was told that it is the cam "trying to hit a lick"; although I agree with the above statement that this cam is not big enough to cause something like that. I have just lived with it...it only does it when I let the car pull itself. As long as I have my foot even a little bit in the throttle, it doesn't do it. I have kinda wondered if it was a drivetrain issue???? Glad you asked this question...we will see what comes up.
You need to post a complete list of your mods.
A picture of the under hood would help as well. Get a Photobucket account (Image hosting, free photo sharing & video sharing at Photobucket, it is free) and put your pictures in it. You can use the IMG tag feature to create the text string you paste into your post to make it display the photo when your post is read.
The car has no codes. As for modes: canfield alum. heads, e303 cam, edelbrock intake, 70mm bbk TB, K&N intake, electric fans, 3.73s, msd ignition, sct eliminator tune, t5. Im not sure wat else it could be beside cam related.
No code 11 (two flashes when the computer dumps the codes)? The 11 code is computer passed its internal self test.
If you don't get an 11, you have computer or wiring problems.
Please check and repost.
Checked again. I have a laptop tht plugs in to the diagnostic port under the hood. It ran 3 test and nothing came up or any codes. So im still leaning towards the cam causing it even though its not tht big.
