E7 Combustion Chamber Cc's
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Does anyone know what the stock combustion chamber on e7 heads is? I have a set of heads with 64 cc chambers.. Wanted to try to figure out what my compression ratio would be with these heads..or I guess if anyone has info on stock pistons that would prob help also.
Low to mid-60's is the general consensus. They vary based on casting, the amount of casting flash, etc, but that's the norm. I've never seen an E7TE head in the 58-60cc range. At leat not without some milling. Compression will be around the 9.0:1 range. A cubic centimeter here or there isn't going to make a lot of difference.
