thanks guys,
the axle housing lines up good for the spring perches. I've run into another problem. I noticed on the third member, there is a pin between the gears where it looks like it's ripped some of the metal apart...
so with that, given that it's a WAR, i'm looking to swap it out for another third member that is worth building up. I found a 9 inch from a 70s truck. it's 31 spline posi. however, this would mean purchasing new axles right? 31 spline and fit to my application?
also, are all ford 9 in third members interchangeable with the axle housing?
I've just heard so many bad things about the WAR case and I don't want to spend the money to get it rebuilt if it's gonna break again...
I appreciate the help!!
