pop the rubber plugs out of the rear drum backing plate and take a flat blade screwdriver and turn the star wheel until you feel a slight drag when spinning the wheel with it safely lifted off the ground - 10 minute job. It would not be a bad idea to pull the wheels & drums and check the condition of the rear brakes - they are really cheap to replace if needed - Advance Auto Parts has drums for $25 each, shoes for $13, both sides hardware spring kit for $4, brake cleaner for $3 and so forth - mine was not working so well & a light grinding sound could be heard when using the e-brake while moving so I checked it out - shoes were shot after 115k miles of use - it is not uncommon to find 100k+ miles on original rear brakes.
