I need to remove the clutch pedal on a 68 coupe. with the clip removed i cant get the shaft to slide all the way out due to interferance with the e brake and a plastic vent assembly. is there an easy way to get this out, should i drop the streering column and unbolt the suport and remove it as an assembly?
