EBAY RETURN WARNING!!!
Omaha Rox
Omaha Ne
Hello All,
Not sure where to post this EBAY warning.
I thought I would try the cheap S/S Headers for SBF 302 for $95.00.
Contacted seller Undergarage and they assured me that these were the same as BBK S/S Headers just un branded.
Headers arrived. they look GREAT! Stainless Steel was nice and Quality looked good.
Tried installing Headers and cylinder 4&5 bolt holes don't line up.
Contacted seller About DEFECTIVE Headers. Seller wanted me to drill out holes and offered discount. NO WAY! I said.
Messaged seller I wanted Refund or Replacement. After Days of messaging seller finally offered a return and told me to select "DID NOT LIKE"
I messaged back Why not choose "ITEM DEFECTIVE" seller gave all kinds of B. S. So I chose "Did not like" and shipped back to seller.
Seller said Headers were used and deducted 50% and refunded 45.00.
I have filed Ebay complaint. Doubt I will win.
Bottom line is NEVER select "DID NOT LIKE" If 'Defective', Even if SELLER tells you to!!!! Select "DEFECTIVE"
Ended up Buying BBK 1 5/8 Headers which fit perfectly even When using Header mounting Studs. Stud Nuts are tight but I managed to get the nuts on the studs.
Hope it works out for you on E-Bay.
The [good] news is that you're here now. We're great at helping people spend their money. :D
So, do you own these crap Chinese headers now? If so, take your time, measure 5 times and mark the header flange. Drop it off to a machine shop and get it drilled. Check the flange for [flatness] with a metal ruler before you install.
Use a quality aftermarket header gasket and quality 12 pt. bolts with Red Loc-tite.
Or... Scrap them and buy a quality set from say... Anderson Ford Motorsports
Reactions: Ronin38
I got mine used,a nice BBK chrome set all blued from use. Paid less then Chinese crap, I used acid toilet bowl cleaner then 2000 degree clear coat and finally DEI lava infused header wrap.They fit perfectly. So a good used part is the best buy. That's my two cents.
Reactions: 08GT500
That’s frigging awful, am sorry to hear. Looks like an assembly line of destruction created these. Quantity, not quality. Sad.
Hard these days with costs going through the roof- but, if it looks too good to be true, it probably is.
I agree with NickyB, used Shorties are readily available, many going w/ longtubes- nice BBK shorties for 100$/BRO- bring a tight gasket, straightedge, once function is established, make them functionally resilient.
Reactions: 5.0-5MT
