E'bock intake/GT40 heads...what cam?
BYRDPE
1,556
Memphis,Tn.
I have the intake/heads and a set of 1.7 rockers.
I'm looking at possibly changing out the cam if I can get 15-20 more horses by doing so.
I'm looking for an OTS cam that has a power band from idle-5800 that I can just install straight up.
I would appreciate any comments on a cam from those that runs or has run a similar set-up.
Thanks
You'd probably be best off just putting the 1.7's on the stock cam. It will work quite well with the intake/exhaust/GT40 heads. Many cars out there with similar combos in the 12's with the stock cam - and no drivability/idle/mileage issues.
this is true, Mike. the other problem is that most cams like 1.6 rockers, not 1.7. although some are made for 1.7s, you will have to pick out the one that best suits your desires and goals.
