ecam and 1.7, around 280-300rwhp?
bigboredave
15
Will I dyno 280-300rwhp with the following combo:
302
cobra intake
gt40p (no work done)
1.7 roller rockers
73mm mas
stock tb
unequal headers
dynomax catback
19lb injectors
car is a t5, with 3.55 gears.
I dont know, that would mean that your pushing 320-340 hp at the crank and that seems alot with your set up. I could be wrong though.
Good luck and let us know when you get it dyno'd
I would think 300rwhp is a little high, I run the E-cam with a little more work done to the engine(see in garage). It runs 107mph in a 3480lbs car this is ~300rwhp(never dyno'd so maybe not). I am swapping the E out, there are way better cams out there OTS or custom.
If you have not purchased this cam I would look around first before you decide. :)
I'd say you're quite a bit more than 300 rwhp if you got that mph in a 3480 lbs. car. :nice:
I have the following and put down 243std hp and 293std tq:
302
Cobra upper/lower intake
75mm holley tb
77mm pro-m mass air meter and intake
1.7rr
30lb injectors
o/r x with flowmasters dumped
t-5 with 3:73 gears
