ecc relay power question
  • Thread starter Thread starter mustang_montana
  • Start date Start date Oct 8, 2006
mustang_montana
137
Oct 8, 2006
  • Oct 8, 2006
still trying to figure out why my fuel pump wont come on, im thinking my new ecc relay is shot but i checked the plug for power and heres what i got:
there are 4 slots, 1 has constant 12 volts, and one has 12 volts when key is on. the one with constant power is #4 when looking at the actual relay, and the one thats on with the key is #2. so the last one is #3 and its supposed to have 12v and be tied in with the fp relay, but it has no power. so im wondering if anyone knows if there is a fuse link that could have broken this circuit. i cant figure out where exactly it gets it power from, but according to the diagram its connected with several solenoids and ends at the ecc.
Blown88GT
2,283
524
164
Palm Beach Gardens, FL
Oct 8, 2006
  • Oct 8, 2006
<<there are 4 slots, >> 4 connections
<<1 has constant 12 volts>> Correct
<<one has 12 volts when key is on>> Correct
<<the one with constant power is #4 when looking at the actual relay, and the one thats on with the key is #2. so the last one is #3 and its supposed to have 12v>> What happened to the 4th terminal? #1 by your definition.
<<and be tied in with the fp relay, but it has no power. so im wondering if anyone knows if there is a fuse link that could have broken this circuit.>> No.
mustang_montana
137
Oct 8, 2006
  • Oct 8, 2006
the 4th terminal has nothing, neither does the second(the one connected with the red wire that powers the injectors/fuel pump etc). i dont understand why there kis no power to that one unless the relay switch is busted and thats how it gets power.
Blown88GT
2,283
524
164
Oct 9, 2006
  • Oct 9, 2006
I don't understand, make a sketch.
12V in Run or Start is R/LG
Gnd is BK/LG
12V at all times is BK/O
12V to Fuel Pump Relay coil is ORG/BK
mustang_montana
137
Oct 9, 2006
  • Oct 9, 2006
if you look at the relay itself it is the last plug on the row with 3. i spliced in a power line to power the fp relay so the pump primes fine, but the injectors arent firing. i may have a leak somewhere in the fuel system because i hear air when i prim the pump. i need to get a pressure gauge cause the tire gauge i used didnt show anything, but theres definetly pressure now, found that out the hard way.
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
D
Fox 88 foxbody no power to red and black wire at fuel pump relay
  • drod88
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
Mcmahst
Electrical Key on power for Fan relay
  • Nine Finger Wrenching
  • Jan 14, 2025
Fox 5.0 Mustang Tech Jan 20, 2025
Engine Carb swapped 89 starting issue
  • cbac89
  • Sep 14, 2024
Fox 5.0 Mustang Tech Sep 14, 2024
General karthief
No power to the fuel pump
  • SNOTTY 5.0
  • Jun 1, 2025
2005 - 2014 S-197 Mustang -General/Talk- Oct 2, 2025
zurliene10
Z
