Where does the Ecu ground in a 94-95 mustang gt. My LC1 is reading wierd, so I want to ground it to the same ground as the ecu. It says in the manual to do this if you are logging through the ecu, so each ground isn't difference for accurate results. I will be logging afr through the egr wire. Thanks
