ECU WIRING!!!??? pod install!?
Deejsylert
ok so i want to install an a/f gauge and ive been seeing that the best way to install would be the puter...I looked at the wiring diagram on veryuseful.com but i still dont understand which wire to connect it to..i know the black wire comming off the seonsor is the signal wire so should i just connect it to that? I want to be able to get a good reading and i dont see how connecting it to one of the o2 sensors could give a good reading?
Also i just purchased the 3 pod full pillar and was wondering how to put it on if i have to drill holes or does it snap over the old one? the instructions that came with it arent very specific!! :bang: :bang:
its not going to read correctly with the readings from the stock o2s. youre just going to get a bunch of flashing lights. to get the real a/f ratio in order to tune the car properly you need a wideband o2 sensor in the exhaust. correct me on this if im wrong someone
i forgot to add i have a 90 gt 5.0! not that it matters much but if someones going to give me the pincodes that could help knowing the year...As for a wideband o2 sensor im not really particular in spending that much money now maybe a little further down the road when i get some serious engine work done but for now id just like to have the gauges connected and working the best for my configuration...im just getting accesorized now so when i save up enough for a decent pony ill have all i need! :shrug:
:bang:
:lol: :banana: :rlaugh: :nonono:
Along with a wideband sensor, you also need a gauge that can read the wideband sensor output. Basically the autometer gauge works only with narrow band, so you have to get a "real" wideband A/F ratio gauge.
im with droptop - i dont think they specifically make pods for us vert guys. my two pod overlayed the stocker. i think, as he said, the 3 pod should replace the stock A pillar trim.
a lot of guys use a toggle switch to go back and forth between the banks. try a search, it has been covered often as to which wires and the colors you tap into.
good luck.
i ended up just replacing the whole pillar...I ran into problems running my fuel gauge but figured it out and it works nice! i put some blue LED's in the gauges it looks amazing!
