edelbrock 60379's comp ex270hr-12- crane 1.7rockers
grippper
494
anyone running the same combo. i need to know what pushrod length your using.way to much valvetrain noise.i cant get it right. do i have to remove the valvs spring to measure.if not maybe ill have a shop go through my valve train.
Xtreme Energy cams are generally noisy, almost like running a solid cam from what I have heard.
What procedure are you following for adjusting your rockers? The pushrod you are running is very close if not optimal unless you have had the heads or deck milled.
