Interesting, I bought the full "RPM" kit for my Windsor but the techs at DSS-Racing talked me into getting a custom grind in between a 270H and the 280H instead of the RPM cam.iskwezm said:I used that cam as a replacement for a comp cam 270.
EXACTLY, this cam has a lot of power in it yet still idles smooth, has a ton of vacuum, and it quite streetable.If you want a good street-strip cam that you can still drive, I think its a good choice.
I had this cam with both a auto and stick,the 270 didnt like my auto and would like lurch even with the stall,the RPM cam was smoother even though it was bigger,that why i say it was more streetableEdbert said:Interesting, I bought the full "RPM" kit for my Windsor but the techs at DSS-Racing talked me into getting a custom grind in between a 270H and the 280H instead of the RPM cam.
2,200 is at the bottom end of acceptable, yet is acceptable. As with most things...ask 5 people for their opinions and get 6 answers, but I put a 2,800 behind basically the same hp/tq curve with a 3.89 rear, and had some folks suggest I go higher still.65notch said:so im pretty well sold on this cam then...you all seem to like it.
here are my mods that iw ould mix it with...
289 .030 over, c-4, comp cams roller tip rockers, stock heads(but rebuilt), rpm intake, 600 edelbrock carb, msd ignition, 3.55 gears.
now for a stall converter.... 2200rpm stall? or should i go higher/lower?
