eeeeggghhhh
  • Thread starter Thread starter TBP
  • Start date Start date Jun 24, 2005
TBP
681
Transient
Jun 24, 2005
  • Jun 24, 2005
OK, that is the best description I can gie of the noise my car is making. This of a really old fashioned oven timer. Not the beeping kind, but the buzzing kind. I have replaced the starter motor, and the starter solenoid. The battery has a good charge, I had it hooked up to a charger all day. Happens when I turn the key. She just won't turn over. Any ideas?
On edit: I also checked and verified all of my grounds.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Jun 24, 2005
  • Jun 24, 2005
seems like when i have heard that sound, i put in a new starter and it is good to go....
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Jun 24, 2005
  • Jun 24, 2005
I know you have covered all the basis and I assume that this problem is the reason for replacing all the parts????
Anyways, although the battery has been on the charger all day it might not be good. Have you had it load tested? Places like Advance Auto do it for nothing. Alternately, try to mount another battery and see what happens.
This one has bit me in the past. . . . .
DukeGnarley
597
Auburn/Ellensburg, Wa
Jun 24, 2005
  • Jun 24, 2005
if it sounds like an oven timer, then it's probably the solinoid, and you're not getting enough juice to it. I would have the battery tested or try another battery if you have one lying around.
ozstang65
313
Queensland, Australia
Jun 24, 2005
  • Jun 24, 2005
If it's a very loud screeching noise, and the car's an automatic, it's probably a worn ring-gear and the motor's stopped in a particularly bad spot on the gear.
Try turning the engine over by hand 1/2 turn or so, then try to start it.
Pretty common problem. I've had old falcons that do it a lot.
TBP
681
Transient
Jun 24, 2005
  • Jun 24, 2005
It's a manual tranny, so that wouldn't be the issue. Thanks anyway.
I am also starting to lean towards a bad battery. The battery is only a month old, however, I have not had it tested. This evening I replaced the battery cables and the solenoid-to-starter cable and still no difference.
To date that means:
New starter
New solenoid
New batt cables
New solenoid-to-starter cable
I do not have an extra battery laying around, but I could always yank the one out of my truck as a test.
2nd Mustang
2,488
Southern California
Jun 24, 2005
  • Jun 24, 2005
How about just jumping batteries with a jumper cable from a known good battery/vehicle? Are you able to check the cells of the battery with a hydrometer for specific gravity? That will tell you if you have a weak or bad cell in the battery in which case no amount of charging is going to help. Hydrometers are pretty cheap at the parts stores.
TBP
681
Transient
Jun 25, 2005
  • Jun 25, 2005
I am going to try a differet battery today. If that doesn't fix it, I don't know what else to do.
Route666
1,652
Brisbane, Australia
Jun 25, 2005
  • Jun 25, 2005
My XE did that too, very very rarely, must have been a couple of teeth missing. I don't see why the same can't happen to a manual car, as it needs teeth for the starter to engage, and I doubt they're any more indestuctible than auto ring gears. It's quite a horrific sound as the starter with no load spins up a storm against what's left of some teeth. Grindy grindy.
TBP
681
Transient
Jun 25, 2005
#10
  • Jun 25, 2005
  • #10
The battery was the culprit. It was only putting out 300 amps, but was rated at over 700. Got a replacement battery and she fired right up. Just got to get her fine tuned.
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
T
Electrical 1990 Vert starting/Solenoid issues
  • Tom77
  • Apr 18, 2025
Fox 5.0 Mustang Tech Apr 18, 2025
85GTStangGuy
F
Alternator Not Charging
  • Fri Guy
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2025
AeroCoupe
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
L
Electrical issue
  • Landonf00
  • Aug 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 10, 2025
Landonf00
L
