EFI conversion progress
  • Thread starter Thread starter 66HertzClone
  • Start date Start date Jan 7, 2006
66HertzClone
428
Central New Jersey
Jan 7, 2006
  • Jan 7, 2006
I all but finished the support I made for the EFI computer. I mounted the computer and all of the other associated parts to it and then fastened down the wiring harness. It will mount under the cowl, one ear will attach to the right side lower wiper pivot mounting bolt. The flange on the front the of the bracket lies against the firewall, it will attch with two sheet metal screws. You can see photos on page seven of my CarDomain link below.
I figured out how to use the existing bell crank for my throttle linkage. I did not want to convert to cabe, trying to keep as much of the vintage look as possible. Anyway, I had an 1 1/2" extension welded on the arm of the bell crank that connects to the throttle body. I used 10x32 size sherical rod ends at both the throttle body and on the bellcrank. These are then connect by 10x32 threaded rod that will be covered with some 1/4 OD stainless tubing to add strength. This system does not have much clearence between the arm on the throttle body and the fuel rail. Using the parts I did, I was able to fit this all together and still have plenty of room. I still need to figure out a throttle return spring system. There is no way to attach one from the front, so I may drill a small hole in the bellcrank arm and attach a spring there to the back of the intake.
Fuel pump mounting and some plumbing will be tackled on Sunday. I plan to run the fuel lines under the hood before I start passing wires thru from the inside of the car.
Assembly has started, well sort of, I at least feel I am making progress.
http://www.cardomain.com/id/66hertzclone
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
  • dan50
  • Jul 18, 2026
dan50
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
