EFI help please
  • Thread starter Thread starter blue66tang
  • Start date Start date Jun 21, 2006
blue66tang
1,092
Medford, OR
Jun 21, 2006
  • Jun 21, 2006
First of all, nice to be back here. I havnt been here in a good six months. Yep my mustang is running great still. I hope to bring it to the drags in a couple weeks and hopefully pull a sub 11.99 pass. Anyway i am working on my 84 cj7. I will be putting a complete 89 5.0 HO in it in the next couple of weeks, and the problem i have been running into, is that there just isnt very much info on this swap. If there is, it says very little about the wiering. I would like to know of a good site/book that goes threw step by step and shows how to get the mustang harnes addapted into the jeep (any non efi) car. I have the mustang and can take anythkng i want. thanks for any help. It will be greatly appreciated. This is a budget build so costly aftermarket wiering is a no go for me. Thanks
R
Ronstang
1,294
Houston Texas
Jun 21, 2006
  • Jun 21, 2006
I simply got the wiring diagrams for the donor car and studied them and found the wires that would need to integrate into the recipient's harness and then used the diagrams for the recipient to know where to hook those up. A little time invested but you completely understand the wiring when done.
88 Fox GT
1,674
Iowa
Jun 21, 2006
  • Jun 21, 2006
When I did my EFI swap, I just bought a harness off of www.fordfuelinjection.com
P
Protowrxs
93
Oklahoma
Jun 21, 2006
  • Jun 21, 2006
Ronstang is right. Once you look over the wiring diagrams and mess with the harness it's surprising how few additional wires there are that actually go to the car. You end up with things like power, grounds, start, run, and sending unit wiring (oil, temp, tach, etc) and the rest is all included in the computer and related harnesses.
Since you have the car available it might be easiest to start from the computer and pull the main harness out and the Injector and O2 items along with it?
One of the best EFI sites to me is still www.FordFuelInjection.com.. lots of info there.
-Stephen
blue66tang
1,092
Medford, OR
Jun 23, 2006
  • Jun 23, 2006
Well the guy with the mustang fell through, he all of a sudden decided he wanted to make a drag car out of it. The good news is that i found another comnplete engine wiering and evertything for 300 bucks. It is already out of the car so i dont have the luxury of knowing where everything goes. He said it iwll come with everything ito make it run, all harneses, belt setup, everything. The thing is, it is for an automatic. So how can i convert this over to stick. I have a 28oz flywheel, but that wont work. Is there anyway i can convert it over to 28oz? What about the computer, will that work with the stick shift. If not all ihave to do is swap computers right? Thanks guys. O one more thing, does a clutch for a 28 oz bolt up to a 50 oz.
Nic
LUCAFU1
496
Tucson
Jun 24, 2006
  • Jun 24, 2006
depends on the code. if its a A9P which came with autos it could be used with a stick
blue66tang
1,092
Medford, OR
Jun 24, 2006
  • Jun 24, 2006
Hmm ill have to find out. He did say that it has had some upgraded chip in it or something, but i will believe that when i see it. Anybody know anything about the flywheel stuff? Thanks
LUCAFU1
496
Tucson
Jun 24, 2006
  • Jun 24, 2006
you can get a new 50oz f/w for 90 bucks or so and then you would be set.
ChopSuey
21
Memphis TN
Jul 1, 2006
  • Jul 1, 2006
If you want read about all there is to swapping a 302 into your jeep go to www.pirate4x4.com and look in the Jeep section. There is a thread on there about 15 pages long that usually stays to the top of the 1st page that has a wealth of information about swapping a 302 into a Jeep.
D
2006 Roush Stage 2 Mustang Chin Spoiler/Lower Grill Inserts Needed
  • DG_Damn_Good
  • Oct 13, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 14, 2026
DG_Damn_Good
D
J
Help finding throttle body
  • jpmaxx
  • Apr 21, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 22, 2026
jpmaxx
J
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
