Is it difficult to go from EFI to carb? I have Fuel Injected motor in my car now, and am planning on getting a DSS 331 shortblock, but want to go carbed.
Thanks
Thanks
bigblock52 said:you know--I just read an article at the afr website with a 331 and they tested fi vs carb. with a speed demon carb they pulled like 30 hp more peak and maintained more hp and tq throughout the rpm range. I do believe it would be easy--bolt on a carb intake and carb- different distributor and maybe throttle cable. If you look at the average fuel mileage of say a 1990 fi mustang and maybe a 1984 stang with a carb I believe they both were advertised to get the same mileage as well. the value of the car would be hurt i would think though. just my two cents.
jrichker said:Another vote for why.
for example in illinois next year the only testing will be of 96 and up carsvristang said:There was a post a short while ago (don't remember if it was here or another site), where a guy had converted late 80's RX-7 to a 5.0. He had all the emissions equipment from the 5.0, but did not have the factory intake tubing. He failed emissions testing.
I realize that many people do not have emissions testing, so this won't affect them.
However, keep in mind that emissions testing will not go away any time soon, and will only become more widespread as time goes on.
Just my thoughts.
Not too mention as the next few years tick by early efi mustangs will be exempt under the antique plates provision, weeeeeeeeeeeeeeeeeeeeeeThat will be REALLY pricey . . . thats why i went carbedmarine_2003 said:I will not be bolting the stock efi stuff onto a 331 motor, if i stay FI then i will buy new EFI stuff, upper, lower injectors, the works. I had a carbed 85 and if i had a fuel problem it was pretty simple to find, as to where with the FI motor, it can be any one injector that stops working, either fuel rail or anything else.
bigblock52 said:
sbftech said:for example in illinois next year the only testing will be of 96 and up carsNot too mention as the next few years tick by early efi mustangs will be exempt under the antique plates provision, weeeeeeeeeeeeeeeeeeeeee
