Exhaust Egr Block Off Screws
There are aftermarket options as well
http://www.jegs.com/p/JEGS-Performa...ll-Block-Ford-Cylinder-Heads/1686929/10002/-1
http://www.summitracing.com/parts/tfs-51400265
The Ford part numbers is F4ZZ-6E086-A. Good luck finding some however. been discontinued for some time
A guy mentioned the jegs set earlier in the thread and that is what I will probably end up going with. I think the trick flow pieces are a tad bit extreme to be asking near 10 bucks a piece.
The best price you'll find on the Thermactor plugs
http://www.store.partsdinosaur.com/product1521.html
Or
5/8-11 x 1" bolt with 2 washers ......2 washers because the holes are slightly deeper than 3/4" before you hit the inside of part of the casting... the washer helps space them out slightly.
5/8-11 x 3/4" threaded bolt is almost impossible to find and that's the reason for the 5/8-11 x 1" bolt.
The Jegs kit is probably going to be the route that I take just to keep it simple.
