  • 1994 - 1995 Specific Tech
EGR blockoff plate: UPDATE
  • Thread starter Thread starter BlueDevil95
  • Start date Start date Apr 21, 2004
BlueDevil95
184
Elkton, MD.
Apr 21, 2004
  • Apr 21, 2004
Well, I got the plate from Wazee today and I threw it on. I removed the actual sensor from the valve and left it plugged in. I then took a zip tie, put it over the plunger and around the base of the sensor tightening the zip tie just enough so that the plunger sunk in about a 1/4 inch. i then wrapped a little electrical tape around the zip tie to keep it in place and tucked the sensor behind the head. I blocked off the vacuum line, fired the car up and viola!, no ce light. Passenger side of the engine looks cleaner and you cant even see the sensor.
greg94080
79
vacaville, ca
Apr 21, 2004
  • Apr 21, 2004
Can you post pics of this? Please forgive for the ignorant questions but this car will no longer pass a smog test correct? Thanks in advance.
-greg
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Apr 21, 2004
  • Apr 21, 2004
You will need both EGR and smog to pass emissions. Maybe not so much the smog as EGR. But if they do a visual check then you fail.
BlueDevil95
184
Elkton, MD.
Apr 22, 2004
  • Apr 22, 2004
Maryland only checks to see that the cats are in place. Removing the egr will not cause the car to fail due to increased emissions, but if your state does a visual inspection, you probably will granted they know what to look for. Sorry, I don't have a digital camera to get pics.
D
DaveB
637
Middlesex and Pomona, NJ
Apr 22, 2004
  • Apr 22, 2004
Where did you get this kit from? Im glad I have the hook up for inspection , even though I've only seen the inspection people check for cats here in NJ.
Badlilstang
1,606
Spring , Texas
Apr 22, 2004
  • Apr 22, 2004
I just used a piece of alluminum plate I cut to block off my EGR where the sensor was... then I cut the pipe and smashed it and folded it over to block it off at the header...worked out well.
BlueDevil95
184
Elkton, MD.
Apr 22, 2004
  • Apr 22, 2004
The company is called Wazee, but I can't find their address and now I can't find the thread I got the address from. Sorry.
D
DaveB
637
Apr 22, 2004
  • Apr 22, 2004
If you find it, please PM it to me, thanks .
D
DaveB
637
Apr 22, 2004
  • Apr 22, 2004
So you just used this
along with the cap for the header and everything worked out?
BlueDevil95
184
Elkton, MD.
Apr 22, 2004
#10
  • Apr 22, 2004
  • #10
yep. except i used a stainless plug i had sitting around in my header.
on my shorties i used to have, i used the stock hose end cap, put a penny in it (don't laugh, it worked) and it sealed up just fine.
BlueDevil95
184
Elkton, MD.
Apr 22, 2004
#11
  • Apr 22, 2004
  • #11
found the link:
http://www.wazeepulleys.com/9495parts/9495parts.htm
Badlilstang
1,606
Spring , Texas
Apr 22, 2004
#12
  • Apr 22, 2004
  • #12
It can throw a check engine light when you block this off. I have an autologic chip and had the EGR function turned off and no problems. I guess thats why you guys are leaving the EGR sensor plugged in?
BlueDevil95
184
Elkton, MD.
Apr 22, 2004
#13
  • Apr 22, 2004
  • #13
you got it. i'm personally not a big chip fan, so this was the next best thing.
G
greg@berkeley
1,172
minnesota / university of california, berkeley
Apr 22, 2004
#14
  • Apr 22, 2004
  • #14
i don't know how much the wazee piece cost you, but a 351 cleveland fuel pump block off plate fits perfectly. i got one at napa for a few bucks, and it worked perfectly.
BlueDevil95
184
Elkton, MD.
Apr 22, 2004
#15
  • Apr 22, 2004
  • #15
good idea.
the wazee piece cost like 10 bucks with shipping off ebay.
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
J
  • JRC99
  • Apr 19, 2025
JRC99
J
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
