EGR blockoff plate: UPDATE
BlueDevil95
184
Elkton, MD.
Well, I got the plate from Wazee today and I threw it on. I removed the actual sensor from the valve and left it plugged in. I then took a zip tie, put it over the plunger and around the base of the sensor tightening the zip tie just enough so that the plunger sunk in about a 1/4 inch. i then wrapped a little electrical tape around the zip tie to keep it in place and tucked the sensor behind the head. I blocked off the vacuum line, fired the car up and viola!, no ce light. Passenger side of the engine looks cleaner and you cant even see the sensor. :banana:
Maryland only checks to see that the cats are in place. Removing the egr will not cause the car to fail due to increased emissions, but if your state does a visual inspection, you probably will granted they know what to look for. Sorry, I don't have a digital camera to get pics. :(
DaveB said:
Where did you get this kit from? Im glad I have the hook up for inspection :nice: , even though I've only seen the inspection people check for cats here in NJ.
The company is called Wazee, but I can't find their address and now I can't find the thread I got the address from. Sorry. :(
So you just used this
along with the cap for the header and everything worked out?
yep. except i used a stainless plug i had sitting around in my header.
on my shorties i used to have, i used the stock hose end cap, put a penny in it (don't laugh, it worked) and it sealed up just fine.
