Engine egr delete help
afso331
15
texas
ok I,v seen so many foxes with the whole smog systm taken out and the egr blocked off with that plate, but iv seen only like two where they actually deleted the the whole egr spacer with that egr spacer plate, why do most everyone keep the egr spacer on, my car now has the delete plate on it, but i goin to buy a 70 tb soon i was wondering why buy the 70mm spacer if i dont need it or should i get it, any advise get greatly appreciated
  • Sponsors(?)
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,357
2,824
234
74
Dublin GA
lowendmac.com
@afso331
Removing the pollution control equipment from a street driven 5.0 Mustang is a bad idea. All you have accomplished is to make the computer mad and spit codes. The pollution control equipment all shuts off at wide open throttle, so the HP losses from it on the car are 2-5 HP. The catalytic converters may soak a few more HP than that. None of the pollution control equipment reduces the HP enough to cost you a race in anything but professional drag strip competition. I seriously doubt that you will be in the final runoff on “Pinks”, so leave the smog equipment in place and make sure it is working correctly.
Know what does what before removing it. Remove or disable the wrong thing and the computer sets the check engine light and runs in "limp mode". Limp mode means reduced power and fuel economy.
If you removed the smog pump and still have catalytic converters, they will ultimately clog and fail.
Here's a book that will get you started with how the Ford electronic engine control or "computer" works.
Ford Fuel Injection & Electronic Engine Control 1988-1993 by James Probst :ISBN 0-8376-0301-3.
It's about $20-$45 from Borders.com see http://www.amazon.com/ . Select books and then select search. Use the ISBN number (without dashes or spaces) to do a search
Use the ISBN number and your local library can get you a loaner copy for free. Only thing is you are limited to keeping the book for two weeks. It is very good, and I found it to be very helpful.
Remove any of the equipment and you will not pass a full smog check, cannot title the car in an area that does smog checks and have broken several federal laws. Granted that the Feds are short on people to check cars, but it is still Federal law.
"Why should I leave the smog equipment on if I live in an area that doesn't do smog inspections?"
What's good sauce for the goose is good sauce for the gander. I lived in Florida and had two smog pumps fail on two different 89 5.0 Mustangs. I replaced both of them, even though there was no emissions inspection. Why?
1.) It a federal law that requires emissions equipment to be in place and functional. I have no intention of breaking a law designed to protect my general health and wellbeing, even if I don't like it. I have respect for the rights and wellbeing of other people, and am not one of those whose nature is rebellion.
2.) Whatever imaginary "improvements" someone may strive for, there is very little evidence that the results of removing emissions results in a better car. I can achieve excellent results in performance with all the smog equipment in place and working properly. Maybe you can't, but that is no excuse for removing the emissions equipment. Look at the new 5.0 Mustangs – 281 cubic inches and 400+ flywheel HP with full emissions equipment with no aftermarket parts. That tells me that it is possible on a mass production car. It also shows that the guys that designed the engine knew what they were doing to achieve that goal.
3.) I like to breathe clean air, and working emissions equipment helps me do my part to make that possible. Los Angeles has breathable air even with millions of cars: Beijing, the capitol of China has some of the worst air in the world. Why – no emissions requirements for cars.
I don’t want to live where the air looks like this…
See http://www.taipeitimes.com/News/feat/archives/2014/01/15/2003581312
Reactions: Mstng93SSP
Thread starter Similar threads Forum Replies Date
B Engine Egr Delete Help!!! Fox 5.0 Mustang Tech 12
krisx125 Deleting Smog Pump And Egr Help! Fox 5.0 Mustang Tech 3
hollywoodstang Need Help with EGR delete, Idles weird, etc,,,etc,,, 1994 - 1995 Specific Tech 14
stevesLX EGR delete kit need help Fox 5.0 Mustang Tech 8
Slow5.0 Need help with EGR delete 1994 - 1995 Specific Tech 1
D EGR delete, need some help Fox 5.0 Mustang Tech 0
Driver460sz Heater tube with EGR delete 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
M Egr delete damage ? SN95 4.6L Mustang Tech 2
9 Sorry Another Egr Delete Thread 1994 - 1995 Specific Tech 14
TrentMO Egr Valve - To Delete Or Not To Delete 1996 - 2004 SN95 Mustang -General/Talk- 16
D How Hard Is To Undo A Egr Delete Kit? 1996 - 2004 SN95 Mustang -General/Talk- 7
splogan Upper Intake Install With Egr Delete 1994 - 1995 Specific Tech 9
blackstangt Engine Egr Delete (conflicting Info) Fox 5.0 Mustang Tech 8
Cupples981 Egr Delete Question SN95 4.6L Mustang Tech 4
E Egr Delete 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
98blackstallion SOLD P/p 75mm Polished T/b With Egr Delete Plate Engine and Power Adder 3
98blackstallion SOLD 75mm Throttle Body Adapter With Egr Delete Plate For 94/95 5.0 Engine and Power Adder Parts 1
NIKwoaC SOLD 70mm Throttle Body, Egr Spacer, And Egr Delete Plate. Engine and Power Adder 5
CarMichael Angelo Engine Lets Talk Pcv/egr Delete. Fox 5.0 Mustang Tech 4
Mark Steele Can I Actually Delete All The Egr Crap? Fox 5.0 Mustang Tech 12
L EGR Delete? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
86ridersrtrue Egr Delete 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
k00ksta Exhaust Egr / Ac Delete Questions 1994 - 1995 Specific Tech 4
ReefBlueHatch UPR EGR Delete Plate Clearance Issues Fox 5.0 Mustang Tech 26
M EGR delete for 03 cobra SVT Tech Forum 0
musclemustangcb egr delete??????ss SN95 4.6L Mustang Tech 12
cobraclone95 EGR delete 1994 - 1995 Specific Tech 13
BlackArtemis Rough idle, after LT install and EGR delete SN95 4.6L Mustang Tech 4
5spd GT Deleted EGR and now have throttle linkage issues, how did you fix it? Fox 5.0 Mustang Tech 2
BlackArtemis How to properly delete/hide EGR vacuum lines? SN95 4.6L Mustang Tech 1
5spd GT For those that have deleted their EGR valve Fox 5.0 Mustang Tech 28
S Edelbrock RPM II & Performer 5.0 Intake, Solid Motor/Trans Mounts 70mm TB/ EGR Delete Engine and Power Adder 0
98blackstallion egr delete plate for intake? 1994 - 1995 Specific Tech 5
J 70mm EGR Spacer Delete Plate Engine and Power Adder 0
ratio411 Do Fox headers work if EGR deleted? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
OrangeMustangGt EGR delete with resistors 1994 - 1995 Specific Tech 1
madspeed EVR removed by PO, should I delete EGR?? Fox 5.0 Mustang Tech 11
Kdubslugga Is an EGR delete this easy?? Fox 5.0 Mustang Tech 4
N What size bolt for EGR delete in cylinder head? Fox 5.0 Mustang Tech 3
Kornnut Pics of EGR delete 1996 - 2004 SN95 Mustang -General/Talk- 18
S EGR tube delete for new headers??? 1994 - 1995 Specific Tech 2
302Feen Has anyone made their own EGR delete plate? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
T 5.0 MAF IAT T/B EGR delete Upper/Lower Engine and Power Adder 0
T 5.0 MAF IAT T/B EGR delete Upper/Lower Engine and Power Adder Parts 2
D egr delete issue Fox 5.0 Mustang Tech 7
93foxbody2.3 EGR delete...now shuts off after warm up!!!! 2.3L (N/A & Turbo) Tech 1
9 EGR and Smog delete 1994 - 1995 Specific Tech 4
F EGR Delete Plate Fox 5.0 Mustang Tech 32
S egr delete SN95 4.6L Mustang Tech 3
MyBloodRunsBlue EGR delete question SN95 4.6L Mustang Tech 7
