egr eliminator....does it work
  • Thread starter Thread starter 91notch5.0
  • Start date Start date Jul 4, 2007
91notch5.0
623
warren mi
Jul 4, 2007
  • Jul 4, 2007
on ebay i see egr a eliminater piece. it is supposed to trick the computer into thinking the egr is hooked up. does anyone have this on a mostly stock mass air equipped mustang.
i'd like to not buy a 70mm egr spacer and just get rid of it instead.
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Jul 4, 2007
  • Jul 4, 2007
Leave the EGR alone. Removing it on a stock car without a custom tune will hurt more than help.
There have been plenty of threads on this. A search will help you understand why.
04sleeper
2,674
14
89
Dallas, TX
Jul 4, 2007
  • Jul 4, 2007
Also, the spacer is where your Throttle Body bolts to so you have to have something. At least a EGR delete plate.
Why do you want to remove it anyway?
A
agent wd/40
North Carolina
Jul 4, 2007
  • Jul 4, 2007
are you talking about the little piece that you plug into your wiring harness if you are i got one on my car i just left the egr in and hooked the coolant lines together no codes runs good just make sure the motor is cold if you want to take the egr out you can by a plate to cover the holes my friend has one and his car runs great
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Jul 4, 2007
  • Jul 4, 2007
Also, after you install the resistor and block off the EGR ports at the heads you will need to slap the car on a dyno and do a custom tune to adjust your part throttle fuel curves otherwise your car will run lean and you will expeirence detonation and potentially damage your motor.
Oh yeah, that;s the part most people forget to do.
The EGR pumps inert gas into the engine at part throttle in order to increase fuel economy a little. At idle and WOT the EGR does not function. Now when you trick the computer into thinking the EGR is functional and not working and then disable it, you need to do something about the computer since it still pulls a little fuel when certain criteria are met and it beleives it has a working EGR. Your air/fuel will run slightly lean.
That's why i always say it isn't worth the effort and to leave the EGR alone.
Now if you redo your engine and plan on getting a custom tune, delete away. But if your mods include basic bolt ons and such, leave the thing 100% functional and focus on REAL performance mods.
A
agent wd/40
North Carolina
Jul 4, 2007
  • Jul 4, 2007
just saying my car runs fine and i have no detonation with 14* timing i put on because my egr was bad it cured my problem i did it because its cheaper than a new egr. if it runs lean pull the vaccum line off the fuel pressure regulator cap the vaccum line you wll have 42lbs of fuel pressure and there is your dyno custom tune lol
91notch5.0
623
warren mi
Jul 5, 2007
  • Jul 5, 2007
i got the 73mm mass air meter, 24# injecters, 70mm throttle body, heads, cam intake, yada yada. i was just being cheap because i didn't want to by the 70mm egr spacer for $50. if buying it avoids a $500 custom tune than it looks like i'll be getting it. thanks guys.
5L5...i still want some wheels like your 96ish cobras! those are sweet.
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Jul 5, 2007
  • Jul 5, 2007
You are still going to need a custom tune either way to properly eliminate it. The chip just tells the computer the EGR is working properly when it's not. You still need to deal with tuning the air/fuel curves.
If you want to avoid the $500 tune, then leave the EGR alone. You either need to do it right (chip, block off EGR ports in heads, custom tune) or not do it at all
And yes i am aware some guys just delete it and call it a day.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jul 5, 2007
  • Jul 5, 2007
with a tweecer you can just tell the ECU that its not even there and that will do the same thing.
Fett
766
#10
  • Jul 5, 2007
  • #10
Basically those plug-in "EGR delete" kits do nothing but keep your PCM from triggering a check engine light....but it doesn't actually delete the EGR from the PCMs functions. A tune can bypass the EGR tables all together.
91notch5.0
623
warren mi
Jul 7, 2007
#11
  • Jul 7, 2007
  • #11
yeah, i'm getting a egr spacer. thanks guys!
Engine Sick of stock TB and EGR spacer...
  • 91GTstroked
  • Dec 15, 2024
Fox 5.0 Mustang Tech Dec 19, 2024
General karthief
  • dan50
  • Jul 18, 2026
dan50
Engine Coolant leak from throttle body
  • 91GTstroked
  • Oct 9, 2023
4K
Fox 5.0 Mustang Tech Apr 27, 2024
91GTstroked
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
