EGR Questions
bdazzgt
I had to jerk off the cable to get it to stop.
Dec 27, 2005
328
Springfield MO
I just put EFI on my car, the EGR is hooked up except the coolant lines that go in the spacer, the reason i did this is because the return plug that goes in the intake after the coolant has been through the spacer wasnt there and i couldnt find a new one could this lead to problems in the future? If so where can i get this plug to change this? Does the EGR need vaccume to operate also? None of the smog equipment is hooked up on my car at all so emissions isnt a worry but if EGR gets me better MPG then i will fix it if i can. And i searched but didnt find much.
Having the EGR functional can save you from possible part-throttle detonation. You do need to have the entire system set-up. The EGR gets its signal to open from the EVR. The EVR is what sends the vacuum signal to the EGR (you can't just run manifold vac to the EGR).
Good luck.
Some basic theory to clarify how things work is in order…
The EGR shuts off at Wide Open Throttle (WOT), so it has minimal effect on performance. The addition of exhaust gas drops combustion temperature, increases gas mileage and reduces the tendency of the engine to ping. It can also reduce HC emissions by reducing fuel consumption.
The EGR system has a vacuum source (line from the intake manifold) that goes to the EVR, computer operated electronic vacuum regulator. The EVR is located on the back of the passenger side shock strut tower. The EGR valve and the passages in the heads and intake manifold route exhaust gas to the EGR spacer (throttle body spacer). The computer uses RPM, Load. and some other factors to tell the EVR to pass vacuum to open the EGR valve. The EGR sensor tells the computer how far the EGR valve is open. Then computer adjusts the signal sent to the EVR to hold, increase or decrease the vacuum. The computer adds spark advance to compensate for the recirculated gases and the slower rate they burn at.
Diagram courtesy of Tmoss & Stang&2birds.
The EGR sensor is basically a variable resistor, like the volume control on a radio. One end is 5 volt VREF power from the computer (red/orange wire). One end is computer signal ground (black/white), and the middle wire (brown/lt green) is the signal output from the EGR sensor. It is designed to always have some small voltage output from it anytime the ignition switch is the Run position. That way the computer knows the sensor & the wiring is OK. No voltage on computer pin 27 (brown/lt green wire) and the computer thinks the sensor is bad or the wire is broken and sets code 31. The voltage output can range from approximately .6-.85 volt.
EGR test procedure courtesy of cjones
to check the EGR valve:
bring the engine to normal temp.
connect a vacuum pump to the EGR Valve
apply 5in vacuum to the valve.
if engine stumbled or died then EGR Valve and passage(there is a passageway through the heads and intake) are good.
if engine did NOT stumble or die then either the EGR Valve is bad and/or the passage is blocked.
if engine stumbled, connect vacuum gauge to the hose coming off of the EGR Valve
snap throttle to 2500 RPM (remember snap the throttle don't hold it there).
did the vacuum gauge show about 5in vacuum?
if not, check for manifold vacuum at the EGR vacuum valve.
if you have manifold vacuum then connect vacuum gauge to the EGR valve side of the vacuum valve and snap throttle to 2500 RPM.
should read about 5in vacuum
The car is a 84 and it doesnt have any smog equipment except the pump. so could I just hook the EGR silenoid to a vaccum source so it could work, is this what you mean hissin? I wasnt aware that this could cause a problems if it wasnt hooked up so i need to get it hooked up asap because detonation=bad. The pipes coming out of the back of heads have been plugged with the thermoacular(sp) screws. I would just like this to work in the simplest manner, i just dont like the thought of detonation. Do i have to have the EVR also, if i do where can i get this? Also the plug that goes in the intake was broken so where could i get another one of these, this is the one that returns coolant to the intake. Thanks again
You are running an EEC-IV engine management system? I am not familiar with stuff older than 86's so I dont want to lead you astray. It sounded like you were running at least a SD set-up, which would mean a computer controlled EGR.
yes i swaped 90 EFI equipement into it, can i just hook that EGR valve to a vaccum source, or do i have to have that EVR valve? IT is a early 80's that i bought cheap and converted to EFI but if this will lead to deationation then i need to fix it because that will kill my new motor.
You need that EVR. EGR does not function at idle or WOT. Manifold vacuum is very high at idle, and if the EGR were wide open because of raw manifold vac, the car would idle very poorly or die.
The EVR opens and closes the EGR, and does so in varying amounts, so the EGR is not noticed and can do its thing.
Good luck.
what does this EVR look like does anyone have a picture?
i might be able to find one from the boneyard if i knew what it looked like also does anyone know where i can get the nipple that screws in the back of the intake? IS there a kit that i can buy that defeats this and makes the computer think it is running ok?
I am not familiar with that kit, but the only proper way to delete the EGR is to take measures which include turning off the EGR function inside the computer.
As Jrichker mentioned, if the computer thinks that the inert EGR gasses are being introduced, when in fact they are not, the car can ping in EGR situation.
The EGR gasses are inert - they make the air/fuel mixture less volatile, as well as having a cooling effect in the chambers. Because of this, the puter adds timing and removes injector dwell while the EGR is active. With no EGR gasses present (after physical EGR deletion, but not turning off the EGR function in the computer), the computer is still thinking that there are inert gasses present, and that added timing and lack of fuel can lead to pinging.
Good luck.
so i would be better off to get the EGR back on until i can afford to buy a tweecer or a chip for my car? I will call RMP tomorrow and see what he says about the EGR delete i am looking for a right way to fix it but the easiest and most cost efficient, i dont make very much $ and this EFI swap broke me for a few weeks but i need to get this going correctly Thanks hissin what would u recommend i do?
I am not there with you, but I need all my smog stuff so I have not played with any of the deletes of any sort.
Now dont get us wrong - quite a few fox folks have deleted the EGR without a tune and they did not report detonation. But many peeps have heard some afterwards. And even if you dont hear any pinging, you can know that you will be running leaner than you or the computer would want (if the computer knew there was no EGR, timing would not be added, nor fuel removed). I sure would not want to take that chance on your new motor.
So you can try it if you want. But if all you need is an EVR, I would get one at the parts store or just ask in here - seems to me that half these folks have removed their smog systems and probably have an EVR lying around in a box that they might let go for shipping costs.
Best of luck with it. :nice:
Actually I might have mine laying around somewhere in my garage if I can find it, b/c I did do the ol' EGR delete trick on my 89 Notch, and alas I do not have any noticeable detonation, so I can lok around and see if I can find that sucker, if you still need it that is?
I was digging through a box of random **** today in the shed and i found a EVR valve i was so happy, i also got the nipple that screws into the intake too, good thing i am a pack rat, the only thing about the EVR is one of the nipples is broke off but my dad thinks he can fix it since he is good and fixing stuff like that, if he cant fix it i will get in touch with you whitenotch, i really appreaciate the offer also thanks again i will let ya guys know how it goes.
