EGR Spacer Leaking
93 LX
3,081
Norwalk, CA.
I have a 93 Stang and since I have owned this car the damn TB / EGR spacer gasket leaks.
I have replaced the gasket several times. The last time I figured there must be something wrong with the sealing surfaces. I took a straight edge and sure enough there is a gap which I fixed using my file. I checked the TB but it is very flat. I also desiced that if i use a soft metal and some RTV I may reduce any other inperfections on the sealing surfaces. In this case I used some lead I had laying around. It has worked for several years but once again its leaking. I noticed that the lead was deformed when I removed it, like there was excessive pressure inside the spacer. I also noticed that the TB studs had work them selves loose and are very rusty. I am going to replace the studs with stainless ones but I am not sure what to do about the EGR spacer.
Should I replace the spacer, should I use copper for the gasket and keep my current spacer, should I remove the water from the spacer?
Any other ides?
Thanks
Allen :shrug:
If your egr system is still intact, then blocking the coolant flow to the spacer is not a good option. The exhaust gas entering the intake is quite warm if not cooled.
I would suspect that the latest problem with the leak was due simply to the bolts/studs backing out. I would try thread locker, and a thin layer of rtv on all mating surfaces.
Those are my thoughts.
best of luck
jason
