Allrighty, let me run something by you guys.
I think my EGR valve is opening at idle after the engines been running for about 30 seconds to a minute.
I made a post earlier about some codes being thrown and was instructed to pull the EGR and clean/check it. Well, it seemed to pass the tests I put it through, so I put it back on and started my truck. It did what it always does, which is crank over and run perfectly for about 30 seconds to a minute then the idle drops and it goes very very rich, doesnt idle well and if you give it gas and let off it'll flood and stumble. This all goes away once its warmed up though. Anyway.. this time when the idle dropped and it started to run crappy I heard a weird kinda noise.. It sounded like, just for a second, the mix didnt ignite properly. What I beleive it was, was Simple Green left in the EGR valve from me cleaning, getting sucked into the combustion chambers when the valve opened at idle. Which of course it shouldnt.
Does this sound logical or am I an idiot? And just as importanly as the verification or denial of my stupidity, would the valve doing this cause the cold running condition I'm experiencing?
Sorry to make so many posts regarding this but Im trying to get to the bottom of it so I can get this problem worked out and out of the way and move on to the important stuff like cleaning my engine bay and walking around in sub 15* weather in shorts.
