Here is the rest of the story.....I just built the engine, with aluminum ported heads, mild cam, and Fords tubular intake manifold. All sensors are new. The EGR goes thru a BBK 75mm spacer. When the engine idles below 900 it has a loud hi-pitched squeal that sounds like a bearing, or a vacuum leak. It is very hard to figure out where the sound is coming from After much effort I've isolated it to the EGR. If I unhook the vacuum line and apply vacuum to the EGR valve, the sound immediately goes away. I took the valve off, and it appears to be in good, clean shape. I resealed it, and no difference. Any suggestions?
