Eibach Front Sway Bar Instructions
Khyron
68
Lincoln, NE
I installed a new Eibach front sway bar on my car, and somehow managed to lose the instruction sheet that explains the different settings for each of the holes in the bar.
Can someone scan in the instruction sheet and/or just type a summary of the explanation for each hole?
Thanks in advance!
Center bore is what you want, the forward bore is soft like stock, and the rear bore is to much load, for track use only.
my instruction book said the forward most hole for aggressive track use, not rear. Just installed mine last weekend.
forward hole - stiffest, rear hole - like stock.
Mine set to forward most hole. holds the front end down during turns, especially when complemented with the prokit :nice:
If you have a sheet then you are correct, I tried finding the FRPP instruction sheet but I didn't have any laying around so I was shooting from memory which is a bad thing to do being I don't remember what I had for breakfast. :rlaugh:
Either which way the middle bore is best for street use.
