It depends on where you live. Figure at 120 degrees out with the AC on, an m8 with a decent radiator will allow a 40 degree rise from a 140 degree air inlet temperature to 180. Now, at an 80 degree ambient temperature, your air inlet will be 100 degrees. You’ll only need 4.4 of the 35A total current draw in order to provide half the airflow.
Given that it’s typically below 80 degrees at night or when it’s raining, the fan will only draw about 4A while your lights or wipers are on. During a hot afternoon, neither will be on, so at a worst case of 120 degree ambient, you’ll have a 10A deficit. If the worst case outside is 110, the highest current the fan will draw is about 18A. The mark viii will cool better than most aftermarket fans at less than half the current, and is the best fan to go with if you want to keep the original alternator.
