  • 2.3L (N/A & Turbo) Tech
elec fan
  • Thread starter Thread starter myboyhasa66
  • Start date Start date Oct 26, 2005
M
myboyhasa66
81
  • Oct 26, 2005
i just bought this electric fan. I know I will have to make brackets but my question is how to control it? do I get an on/off switch or a low/high/off switch? Im gonna be running a 94 ranger radiator probably with an npr and stinger piping.
http://www.corral.net/forums/showthread.php?t=696309
( i bought it on ebay for cheaper)
rd
3,316
63
109
Ocean Springs MS
Oct 26, 2005
  • Oct 26, 2005
For a basic electric fan, I would power the fan with a relay, usually 30 amp minimum, continous duty. Check the fan specs
It can be controlled by a simple switch to the relay, or best done by using a thermostatic switch. Not sure what vehicle you are installing it on. There are fan control kits that use sensors that just mount in the air stream on the back of the radiator, and those that use switches that mount in the cooling system. A 2.3 has 3 in it already, one for the EEC, one for the gage, and one for the orig electric fan controller. Some run these hot all the time so the fan runs until the system is cool, but I would power the switch from a keyed source.
The temp sensor in the coolant system is best, and can be installed in parallel with a manual switch for over ride, and or for activation when the ac is on.
I would not power the fan directly with an switch, because the length of wire is such that you will need 10 or 8 ga wire and a 30 amp or heavier switch.
M
myboyhasa66
81
  • Oct 27, 2005
okay great. the car is a 91 lx by the way and thanks a lot.-marcin
88stangmangt
2,332
Stafford,VA
Oct 27, 2005
  • Oct 27, 2005
mine is controlled by the computer.....everything was just swapped over from a TC it is a dual fan set-up and it works well.
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
D
6G alternator pigtail wiring help needed
  • Dogman_1969
  • Aug 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 11, 2025
Dogman_1969
D
V
Cooling fan low speed not turning on
  • vman
  • Feb 27, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 24, 2025
vman
V
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
