Electirc fan question. I installed the 3.8 Taurus electric fan in my cobra. I used the Flex adjust fan control that wraps a capillary tube under the upper rad. hose and has the temp. sense bulb in the water flow into the rad.. Here is my question, I want to put a relay in series with the temp switch so that the fan will only run when the engine is running. Not just the key turned on but the engine actually running. Can I pull the 12V for the relay off the stator wire white w/black tracer that goes to the choke too?
Thanks guys,
Tim
Thanks guys,
Tim
